Ga door naar hoofdinhoud
PlayStation VR Processor Unit Cooling Fan Replacement
Wat je nodig hebt
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: stap 1, afbeelding 1 van 3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: stap 1, afbeelding 2 van 3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: stap 1, afbeelding 3 van 3
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. PlayStation VR Processor Unit Cooling Fan Replacement: stap 2, afbeelding 1 van 3 PlayStation VR Processor Unit Cooling Fan Replacement: stap 2, afbeelding 2 van 3 PlayStation VR Processor Unit Cooling Fan Replacement: stap 2, afbeelding 3 van 3
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. PlayStation VR Processor Unit Cooling Fan Replacement: stap 3, afbeelding 1 van 2 PlayStation VR Processor Unit Cooling Fan Replacement: stap 3, afbeelding 2 van 2
    • Slide the panel back into place.
  4. PlayStation VR Processor Unit Cooling Fan Replacement: stap 4, afbeelding 1 van 3 PlayStation VR Processor Unit Cooling Fan Replacement: stap 4, afbeelding 2 van 3 PlayStation VR Processor Unit Cooling Fan Replacement: stap 4, afbeelding 3 van 3
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  5. PlayStation VR Processor Unit Cooling Fan Replacement: stap 5, afbeelding 1 van 1
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  6. PlayStation VR Processor Unit Cooling Fan Replacement: stap 6, afbeelding 1 van 2 PlayStation VR Processor Unit Cooling Fan Replacement: stap 6, afbeelding 2 van 2
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  7. PlayStation VR Processor Unit Cooling Fan Replacement: stap 7, afbeelding 1 van 2 PlayStation VR Processor Unit Cooling Fan Replacement: stap 7, afbeelding 2 van 2
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Sarah Shand
1.885 Reputatie
7 handleidingen geschreven
USF Tampa, Team S3-G1, Sullivan Spring 2017 Lid van USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Leden
13 handleidingen geschreven
4 opmerkingen
Where do I get a replacement fan tho?
Ponos King - Antwoord
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - Antwoord
5V is what i have read
Ethan Amos -
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 53
Altijd: 8,726
