Ga door naar hoofdinhoud
PlayStation Start and Select Buttons Replacement
Wat je nodig hebt
  1. PlayStation Start and Select Buttons Replacement, Start and Select Buttons: stap 1, afbeelding 1 van 1
    • Before you begin, unplug your controller and console to avoid accidentally turning it on during disassembly.
  2. PlayStation Start and Select Buttons Replacement: stap 2, afbeelding 1 van 3 PlayStation Start and Select Buttons Replacement: stap 2, afbeelding 2 van 3 PlayStation Start and Select Buttons Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the five 7.2 mm screws securing the rear cover.
  3. PlayStation Start and Select Buttons Replacement: stap 3, afbeelding 1 van 3 PlayStation Start and Select Buttons Replacement: stap 3, afbeelding 2 van 3 PlayStation Start and Select Buttons Replacement: stap 3, afbeelding 3 van 3
    • Gently push the rear cover towards the front of the #2 trigger buttons.
    • Lift the rear cover.
    • The #2 trigger buttons may come off when removing the cover.
  4. PlayStation Start and Select Buttons Replacement: stap 4, afbeelding 1 van 2 PlayStation Start and Select Buttons Replacement: stap 4, afbeelding 2 van 2
    • Lift the battery and set it beside the controller, with care not to strain the wires.
    • Use a Phillips #1 screwdriver to remove the single 7.2 mm screw securing the motherboard.
  5. PlayStation Start and Select Buttons Replacement: stap 5, afbeelding 1 van 2 PlayStation Start and Select Buttons Replacement: stap 5, afbeelding 2 van 2
    • Unclip the vibrating motors.
    • Be careful not to break the black and red wires connected to the motherboard. They are very fragile!
  6. PlayStation Start and Select Buttons Replacement: stap 6, afbeelding 1 van 2 PlayStation Start and Select Buttons Replacement: stap 6, afbeelding 2 van 2
    • Lift off the plastic housing holding the motherboard, battery, and vibrating motors.
  7. PlayStation Start and Select Buttons Replacement: stap 7, afbeelding 1 van 3 PlayStation Start and Select Buttons Replacement: stap 7, afbeelding 2 van 3 PlayStation Start and Select Buttons Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the rubber buttons with a pair of tweezers.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 25
Afgelopen 30 dagen: 86
Altijd: 1,582
