Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Insert the plastic opening tool at the indent.
Gently use a forward and backward motion to safely pop open the cover.
Using your hands to further pull it apart.
Once the device is opened, lift the battery out of the black plastic holder.
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Gently pull out the small grey cylindrical piece (vibrator).
Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
Remove by squeezing the inner plastic frame, lift and pull it towards you.
Gently pull on the white piece connecting the battery and the connector.
Remove the five 1.2 mm screws from upper portion of the controller.
Cautiously remove the circular white piece at the top without removing the LED inside.
Remove the blue strip that is connected to the trigger button from the motherboard.
Één opmerking
This disassembly is destructive (namely to the LED connector as it is soldered to the main board) and has many unnecessary steps for simply replacing the trigger button assembly. It also says no parts are required but you would clearly need replacement trigger parts.
