Onderdelen
Geen onderdelen opgegeven.
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Bijna klaar!
Conclusie
Één commentaar
This disassembly is destructive (namely to the LED connector as it is soldered to the main board) and has many unnecessary steps for simply replacing the trigger button assembly. It also says no parts are required but you would clearly need replacement trigger parts.
