Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Insert the plastic opening tool at the indent.
Gently use a forward and backward motion to safely pop open the cover.
Using your hands to further pull it apart.
Once the device is opened, lift the battery out of the black plastic holder.
Using a Phillips head screwdriver, remove the 9mm screw located to the right of the battery, which is connected to the inner plastic frame.
Using the plastic opening tool carefully take out the grey cylindrical piece (vibrator) that is also attached to a wire.
Gently pull out the small grey cylindrical piece (vibrator).
Using tweezers, remove the small piece with a cylindrical top that is located to the left of the inner plastic frame.
Using one hand to hold the device, and the other hand to squeeze the inner plastic frame.
Remove by squeezing the inner plastic frame, lift and pull it towards you.
Gently pull on the white piece connecting the battery and the connector.
8 andere personen hebben deze handleiding voltooid.
4 opmerkingen
When putting the plastic battery rig back in on my second time doing this, I bent one of the little plastic pins that fits into a hole in the PCB. Definitely want to be careful with that. To make it a bit easier, I unscrewed the bottom port PCB part of the way so I could take the bottom plastic housing and put the plastic battery rig in straight. It made it a lot easier.
Worked great! Thanks for this. I did not need to take out the black battery / motor piece. Tweezers worked great to remove and install the battery cable
Any recommended online / physical store to buy new batteries for this because ifixit doesn’t have them?
