Inleiding
This will guide you through the process of replacing your logic board.
Gereedschap
Onderdelen
Geen onderdelen nodig.
Remove the parallel port cover on the back of the PlayStation.
Carefully disconnect the gold-colored ribbon cable from it's connector.
With one hand, hold the main board’s protective metal cover. With your other hand, wedge the spudger in between the right side of the protective cover and the thin metal clamps that surround it.
With the spudger in place, gently lift the upper portion of the metal cover. The cover should detach from the right side.
13 andere personen hebben deze handleiding voltooid.
