Ga door naar hoofdinhoud
PlayStation 4 Slim Thermal Paste Replacement
Wat je nodig hebt
Video overzicht
  1. PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: stap 1, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: stap 1, afbeelding 2 van 2
    • Remove the panel next to the ports by sliding it to the right.
    • Use a Philips PH1 screwdriver to remove the screw.
  2. PlayStation 4 Slim Thermal Paste Replacement: stap 2, afbeelding 1 van 1
    • Pull the black ribbon on the side of the PS4 to remove the hard drive.
  3. PlayStation 4 Slim Thermal Paste Replacement: stap 3, afbeelding 1 van 1
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Peel off the plastic warranty sticker next to the three ports on the side of the console.
    • Use a T9 Torx security screwdriver to remove the screw.
  4. PlayStation 4 Slim Thermal Paste Replacement: stap 4, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 4, afbeelding 2 van 2
    • Flip the PS4 with the bottom side facing upwards and the side of the screw you just removed facing you.
    • Remove the cover by prying the two corners and then sliding it back.
    • This step will require some force and you will hear clicking sounds as the cover is coming off.
  5. PlayStation 4 Slim Thermal Paste Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove this screw.
  6. PlayStation 4 Slim Thermal Paste Replacement: stap 6, afbeelding 1 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 6, afbeelding 2 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 6, afbeelding 3 van 3
    • Remove the three T9 Torx security screws.
    • Use a Phillips #0 screwdriver to remove the two screws.
    • Lift and remove the metal panel after unscrewing.
  7. PlayStation 4 Slim Thermal Paste Replacement: stap 7, afbeelding 1 van 1
    • Remove the power supply completely by disconnecting the wire.
  8. PlayStation 4 Slim Thermal Paste Replacement: stap 8, afbeelding 1 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 8, afbeelding 2 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 8, afbeelding 3 van 3
    • Flip the PS4 to view the metal paneling.
    • Lift the black clip on the largest connection to remove it.
    • Disconnect the wire by pulling it back with a little bit of force.
    • By pulling on the blue tabs gently you are able to remove the connections.
    • Gently lift the black wire to disconnect from the motherboard.
  9. PlayStation 4 Slim Thermal Paste Replacement: stap 9, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 9, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove all screws.
    • After unscrewing, remove the metal panel to access the motherboard.
    • Removing the metal panel may require some force but do not pull up too hard as you may have missed a screw.
  10. PlayStation 4 Slim Thermal Paste Replacement: stap 10, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 10, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove two screws.
    • Unplug the wire by pulling firmly.
    • Lift the metal brace with your fingers to expose the motherboard.
  11. PlayStation 4 Slim Thermal Paste Replacement: stap 11, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 11, afbeelding 2 van 2
    • Apply 2-3 droplets of thermal material remover on Q-tips to remove the old thermal paste and then wipe it down with a micro fiber cloth until no residue of old paste is left.
    • Apply 2-3 droplets of thermal surface purifier on a new Q-tip and go over the area cleaned.
    • Both steps may require multiple repetitions.
  12. PlayStation 4 Slim Thermal Paste Replacement: stap 12, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 12, afbeelding 2 van 2
    • Squeeze about 3/4 of an inch of Arctic Silver 5 thermal paste onto the prepared surface.
    • Let the thermal paste rest for 10 minutes before reassembly.
  13. PlayStation 4 Slim Thermal Paste Replacement: stap 13, afbeelding 1 van 1
  14. PlayStation 4 Slim Thermal Paste Replacement: stap 14, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 14, afbeelding 2 van 2
    • Flip the console.
    • Use a Phillips #0 screwdriver to remove the screw.
  15. PlayStation 4 Slim Thermal Paste Replacement: stap 15, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 15, afbeelding 2 van 2
    • Lift up the metal panel and on the back the radiator is located.
    • Clean the radiator by using a brush and a compressed air can.
  16. PlayStation 4 Slim Thermal Paste Replacement: stap 16, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 16, afbeelding 2 van 2
    • Clean the fan by using a brush and a compressed air can.
Conclusie
63 andere personen hebben deze handleiding voltooid.
Muhammad Saif Khan
1.942 Reputatie
1 Handleiding geschreven
7 opmerkingen
Hey, can I use this for a original “fat” ps4?
thanks
notle159 - Antwoord
Any advice on a good way to clean the fan blades? Thanks for all the other tips!
Nicholas Pratt III - Antwoord
Thanks for the instructions, they helped me a lot!!! If there's one thing Sony didn't save on this console, it was screws 😂😂😂
Ferrera_Gabs - Antwoord
La guía es muy fácil de seguir y los resultados superaron mis expectativas, la falla de recalentamiento ya no aparece más. Gracias!!
Alexis Astorga - Antwoord
This guy helped me take apart my PS4 slim and put it together!! Super happy for being able to do this without much experience as well as anxiety lol. One thing to note is that I had way more screws than what this guide showed. I also had an extra connecting piece alongside Step 8 where it tells you to "Gently lift the black wire to disconnect from the motherboard." Don't know what that piece does and I don't care as long as it works! All in all, great guide. My PS4 still works, cleaned up and able to be used for a few more years before I switch to a PS5 :)
Chat Chai - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 73
Afgelopen 7 dagen: 624
Afgelopen 30 dagen: 2,915
Altijd: 91,380
