Ga door naar hoofdinhoud
PlayStation 4 Slim Thermal Paste Replacement
Wat je nodig hebt
Video overzicht
  1. PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: stap 1, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement, Thermal Paste: stap 1, afbeelding 2 van 2
    • Remove the panel next to the ports by sliding it to the right.
    • Use a Philips PH1 screwdriver to remove the screw.
  2. PlayStation 4 Slim Thermal Paste Replacement: stap 2, afbeelding 1 van 1
    • Pull the black ribbon on the side of the PS4 to remove the hard drive.
  3. PlayStation 4 Slim Thermal Paste Replacement: stap 3, afbeelding 1 van 1
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Peel off the plastic warranty sticker next to the three ports on the side of the console.
    • Use a T8 Torx security screwdriver to remove the screw.
  4. PlayStation 4 Slim Thermal Paste Replacement: stap 4, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 4, afbeelding 2 van 2
    • Flip the PS4 with the bottom side facing upwards and the side of the screw you just removed facing you.
    • Remove the cover by prying the two corners and then sliding it back.
    • This step will require some force and you will hear clicking sounds as the cover is coming off.
  5. PlayStation 4 Slim Thermal Paste Replacement: stap 5, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove this screw.
  6. PlayStation 4 Slim Thermal Paste Replacement: stap 6, afbeelding 1 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 6, afbeelding 2 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 6, afbeelding 3 van 3
    • Remove the three T8 Torx security screws.
    • Use a Phillips #1 screwdriver to remove the two screws.
    • Lift and remove the metal panel after unscrewing.
  7. PlayStation 4 Slim Thermal Paste Replacement: stap 7, afbeelding 1 van 1
    • Remove the power supply completely by disconnecting the wire.
  8. PlayStation 4 Slim Thermal Paste Replacement: stap 8, afbeelding 1 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 8, afbeelding 2 van 3 PlayStation 4 Slim Thermal Paste Replacement: stap 8, afbeelding 3 van 3
    • Flip the PS4 to view the metal paneling.
    • Lift the black clip on the largest connection to remove it.
    • Disconnect the wire by pulling it back with a little bit of force.
    • By pulling on the blue tabs gently you are able to remove the connections.
    • Gently lift the black wire to disconnect from the motherboard.
  9. PlayStation 4 Slim Thermal Paste Replacement: stap 9, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 9, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove all screws.
    • After unscrewing, remove the metal panel to access the motherboard.
    • Removing the metal panel may require some force but do not pull up too hard as you may have missed a screw.
  10. PlayStation 4 Slim Thermal Paste Replacement: stap 10, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 10, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove two screws.
    • Unplug the wire by pulling firmly.
    • Lift the metal brace with your fingers to expose the motherboard.
  11. PlayStation 4 Slim Thermal Paste Replacement: stap 11, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 11, afbeelding 2 van 2
    • Apply 2-3 droplets of thermal material remover on Q-tips to remove the old thermal paste and then wipe it down with a micro fiber cloth until no residue of old paste is left.
    • Apply 2-3 droplets of thermal surface purifier on a new Q-tip and go over the area cleaned.
    • Both steps may require multiple repetitions.
  12. PlayStation 4 Slim Thermal Paste Replacement: stap 12, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 12, afbeelding 2 van 2
    • Squeeze about 3/4 of an inch of Arctic Silver 5 thermal paste onto the prepared surface.
    • Let the thermal paste rest for 10 minutes before reassembly.
  13. PlayStation 4 Slim Thermal Paste Replacement: stap 13, afbeelding 1 van 1
    • Use a Phillips #0 screwdriver to remove the two screws.
  14. PlayStation 4 Slim Thermal Paste Replacement: stap 14, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 14, afbeelding 2 van 2
    • Flip the console.
    • Use a Phillips #0 screwdriver to remove the screw.
  15. PlayStation 4 Slim Thermal Paste Replacement: stap 15, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 15, afbeelding 2 van 2
    • Lift up the metal panel and on the back the radiator is located.
    • Clean the radiator by using a brush and a compressed air can.
  16. PlayStation 4 Slim Thermal Paste Replacement: stap 16, afbeelding 1 van 2 PlayStation 4 Slim Thermal Paste Replacement: stap 16, afbeelding 2 van 2
    • Clean the fan by using a brush and a compressed air can.
Conclusie
74 andere personen hebben deze handleiding voltooid.
Muhammad Saif Khan
2.206 Reputatie
1 Handleiding geschreven
11 opmerkingen
Hey, can I use this for a original “fat” ps4?
thanks
notle159 - Antwoord
the original fat ps4 uses a different design than the slim one
alden dufresne -
Any advice on a good way to clean the fan blades? Thanks for all the other tips!
Nicholas Pratt III - Antwoord
Thanks for the instructions, they helped me a lot!!! If there's one thing Sony didn't save on this console, it was screws 😂😂😂
Ferrera_Gabs - Antwoord
La guía es muy fácil de seguir y los resultados superaron mis expectativas, la falla de recalentamiento ya no aparece más. Gracias!!
Alexis Astorga - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 84
Afgelopen 7 dagen: 469
Afgelopen 30 dagen: 2,382
Altijd: 111,441
