Ga door naar hoofdinhoud
PlayStation 4 Slim Hard Drive Replacement
Wat je nodig hebt
  1. PlayStation 4 Slim Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 2 PlayStation 4 Slim Hard Drive Replacement, Hard Drive: stap 1, afbeelding 2 van 2
    • Slide your thumb to the right to remove the plastic cover.
  2. PlayStation 4 Slim Hard Drive Replacement: stap 2, afbeelding 1 van 2 PlayStation 4 Slim Hard Drive Replacement: stap 2, afbeelding 2 van 2
    • Remove the silver 6 mm #0 Phillips screw that holds the hard drive caddy in place using your screwdriver.
    • This screw is very important as it ensures the drive does not come loose from the connector during operation.
  3. PlayStation 4 Slim Hard Drive Replacement: stap 3, afbeelding 1 van 3 PlayStation 4 Slim Hard Drive Replacement: stap 3, afbeelding 2 van 3 PlayStation 4 Slim Hard Drive Replacement: stap 3, afbeelding 3 van 3
    • Pull out the black glossy tape handle using your fingers.
    • Remove the caddy from the bay.
  4. PlayStation 4 Slim Hard Drive Replacement: stap 4, afbeelding 1 van 3 PlayStation 4 Slim Hard Drive Replacement: stap 4, afbeelding 2 van 3 PlayStation 4 Slim Hard Drive Replacement: stap 4, afbeelding 3 van 3
    • Remove all four 8 mm Phillips #0 screws from the hard drive caddy (two on each side).
  5. PlayStation 4 Slim Hard Drive Replacement: stap 5, afbeelding 1 van 2 PlayStation 4 Slim Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Slide your hand under the sled opening near the black tape handle, and press one of your fingers against the slate drive to push it up.
    • Carefully extract the hard drive from the caddy.
  6. PlayStation 4 Slim Hard Drive Replacement: stap 6, afbeelding 1 van 2 PlayStation 4 Slim Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Place your replacement hard drive or solid-state drive into the caddy.
    • Make sure the drive is upside with the connector's golden pins facing up like so.
    • Also be sure the connector is facing away from the black tape handle. This and the above point will ensure proper connection to the Playstation 4.
    • If installing a solid-state drive, make sure the screw holes of the sled and the drive are aligned properly before screwing back in.
    • This isn't a problem with 2.5" hard disk drives since the thickness allows for proper alignment during placement.
Conclusie
To reassemble your device, follow these instructions in reverse order starting from Step 4.
Be sure to have a USB stick ready with an official PS4 firmware update file from Sony's website to reinstall the system software on your new hard disk or solid state drive. Follow Sony's instructions for formatting the USB as well.
3 andere personen hebben deze handleiding voltooid.
Jordan Crooks
205 Reputatie
1 Handleiding geschreven
UC Davis, Team 3-7, Andersen Winter 2024 Lid van UC Davis, Team 3-7, Andersen Winter 2024
UCD-ANDERSEN-W24S3G7
2 Leden
3 handleidingen geschreven
Één opmerking
I need help why is my ps4 slim not turning on, all it does Is show the Play Station logo then the screen is black then turns off?
Henry Ramsey - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 117
Afgelopen 30 dagen: 746
Altijd: 1,179
