Ga door naar hoofdinhoud
PlayStation 4 Slim Bottom Cover Replacement
Wat je nodig hebt
  1. PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 PlayStation 4 Slim Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Locate the plastic warranty sticker next to the three ports on the side of the console.
    • Remove the warranty sticker by peeling it off with any kind of spudger.
    • Removing the warranty sticker will NOT cause your warranty to be null and void.
  2. PlayStation 4 Slim Bottom Cover Replacement: stap 2, afbeelding 1 van 2 PlayStation 4 Slim Bottom Cover Replacement: stap 2, afbeelding 2 van 2
    • Unscrew and remove the now exposed 5.0mm screw using a TR8 security Torx screwdriver with a counter-clockwise motion.
  3. PlayStation 4 Slim Bottom Cover Replacement: stap 3, afbeelding 1 van 3 PlayStation 4 Slim Bottom Cover Replacement: stap 3, afbeelding 2 van 3 PlayStation 4 Slim Bottom Cover Replacement: stap 3, afbeelding 3 van 3
    • Place the Playstation 4 Slim upside down with the side of the screw you just removed facing you.
    • Pry up on the two corners that are facing you with your fingers.
    • This may take a bit of force to open up and you will hear a fairly loud click when the bottom cover detaches.
    • Remove the bottom cover by sliding it towards the back corners and lifting up.
Conclusie
45 andere personen hebben deze handleiding voltooid.
Hernan Rodriguez
4.070 Reputatie
3 handleidingen geschreven
Cal Poly, Team S19-G4, Livingston Winter 2018 Lid van Cal Poly, Team S19-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S19G4
4 Leden
35 handleidingen geschreven
2 opmerkingen
Wo kann man die Bodenplatte kaufen?
Emre Kaman - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 41
Afgelopen 7 dagen: 246
Afgelopen 30 dagen: 872
Altijd: 57,282
