Ga door naar hoofdinhoud
PlayStation 4 Pro Power Supply Unit Replacement
Wat je nodig hebt
  1. PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement, Power Supply Unit: stap 1, afbeelding 3 van 3
    • Begin by flipping the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. PlayStation 4 Pro Power Supply Unit Replacement: stap 2, afbeelding 1 van 2 PlayStation 4 Pro Power Supply Unit Replacement: stap 2, afbeelding 2 van 2
    • Use a screwdriver to remove the single Phillips #0 screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. PlayStation 4 Pro Power Supply Unit Replacement: stap 3, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 3, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 3, afbeelding 3 van 3
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. PlayStation 4 Pro Power Supply Unit Replacement: stap 4, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 4, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 4, afbeelding 3 van 3
    • Use a T8 Torx Security screwdriver to remove the five screws.
    • Two 31mm screws.
    • Three 10mm screws.
    • Remove the metal plate.
    I couldn’t open the middle 10mm screw with T8 Torx Security screwdriver :(
    Rifat Nabi - Antwoord
    I can’t get that middle black screw out with anything. My torx isn’t doing anything.
    Cai Hayz - Antwoord
    How do I get the middle plastic black screw out? It's not doing anything but stripping it.
    Mike Strong - Antwoord
    it’s like rubber or something on that middle screw.
    Coker Lisonbee - Antwoord
    On newer models the black screw in the middle is just plastic and does not have to be removed. Skip it or you’ll just drive yourself crazy and end up producing a small pile of plastic-dust and that’s it.
    Allan Paiste - Antwoord
  5. PlayStation 4 Pro Power Supply Unit Replacement: stap 5, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 5, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 5, afbeelding 3 van 3
    • Flip the console to its back once again.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel.
    • Remove the bottom cover in the same way as the top cover. Grip on both sides, pull up until a click is heard and slide off.
    If you have a console that has not been fixed before - these screws will be hidden under warranty stickers - so make sure you understand that completing this step will basically void the warranty.
  6. PlayStation 4 Pro Power Supply Unit Replacement: stap 6, afbeelding 1 van 2 PlayStation 4 Pro Power Supply Unit Replacement: stap 6, afbeelding 2 van 2
    • Use a T8 Torx security screwdriver to remove the two 10mm silver screws from the metal plate.
  7. PlayStation 4 Pro Power Supply Unit Replacement: stap 7, afbeelding 1 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 7, afbeelding 2 van 3 PlayStation 4 Pro Power Supply Unit Replacement: stap 7, afbeelding 3 van 3
    • Flip the console over to continue working on the top side.
    • Place fingers underneath edge of power supply unit on both sides and pull straight up.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
    If you are having trouble lifting the power supply from the system with all screws already out flip the system over and push inward and up on the plug
    blake - Antwoord
    what kind of wire is that ive been looking everywhere for a replacement
    craclighterr - Antwoord
    Are all ps4 pro power supply models compatible with all motherboard models? I want to change all the components from a newer ps4 pro to a white ps4 pro, but this one has different power cable and should keep its power supply. Is this possible?
    icaroxp - Antwoord
    Nice, pretty detailed repair work done, thanks!
    kmsit - Antwoord
    There are 3 different power supplies for the pro model.......... take it apart and read the numbers off it to make sure you get the correct one. 300ER, 300CR, 300FR
    Alan Sears - Antwoord
    This is the only screw I can't get out on top of the power supply so I can replace my pasta what size is it
    MillerGuy2008 - Antwoord
    This is the screw I had trouble with I don't know why and it's the only screw holding the power supply in on top in the middle when you take the foil off
Conclusie
36 andere personen hebben deze handleiding voltooid.
Ashlyn Chow
3.345 Reputatie
1 Handleiding geschreven
Cal Poly, Team S21-G5, Livingston Spring 2017 Lid van Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Leden
49 handleidingen geschreven
10 opmerkingen
Thank you soooo much for helping me save my ps4 pro guys! At the moment I love you like no one before! ;D
Fayce D D - Antwoord
Can you go further in your tear-down and show us how to open up the power supply without breaking the PSU plastic case? Thanks. ^_^
Matt - Antwoord
I bought a PS4 power supply CR 300 and my PS4 has an FR 300 power supply will they interchange
joseph fish - Antwoord
My PlayStation Pro has a power supply FR 300 and the power supply I bought was a CR 300 power supply will they interchange
Hola como saber que tipo de fuente vida mi ps4 pro modelo 7215b
Tomás Javier - Antwoord
Solucionaste el problema?
JUZZ0U_XIII -
for anyone attempting this please note that the motherboard connector for the power supply is very fragile and might break off will trying to disconnect. Try pinching the connector on the motherboard and gently pulling on the cables to try and keep that from happening
Markus Cevera - Antwoord
When the power supply finally fails, is this a fire hazard?
dotcomtim - Antwoord
Good morning do you have a number to call for I can call about a ps4 Pro
Pompanothekidd - Antwoord
Because I need my PS4 to get fixed I think one of the cords inside of it is broken and it do not want to turn on and stuff like that so ya what is the number I can contact you on
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 156
Afgelopen 30 dagen: 747
Altijd: 91,140
