Ga door naar hoofdinhoud
PlayStation 4 Pro Hard Drive Replacement
Wat je nodig hebt
  1. PlayStation 4 Pro Hard Drive Replacement, Hard Drive Cover: stap 1, afbeelding 1 van 1
    • Start by flipping the PS4 Pro over its top.
    • Remove the plastic panel covering the drive bay, using the tab next to the Ethernet port.
  2. PlayStation 4 Pro Hard Drive Replacement, Hard Drive Caddy: stap 2, afbeelding 1 van 1
    • Remove the Phillips #0 screw securing the hard drive caddy to the chassis.
  3. PlayStation 4 Pro Hard Drive Replacement, Hard drive: stap 3, afbeelding 1 van 1
    • Slide the hard drive caddy out.
    • Remove the four Phillips #0 screws securing the hard drive to the caddy.
Conclusie
63 andere personen hebben deze handleiding voltooid.
Ronnie
3.495 Reputatie
5 handleidingen geschreven
7 opmerkingen
Bought a screwdriver from amazon and didn’t work. Bought the screwdriver linked on this guide and it worked flawlessly. Thanks
javz - Antwoord
Does this work the same for PS4 slim?
Matthew - Antwoord
i want to change the hard drive in my ps4 to a 5tb (2.5”) but does this transfer trophies if i don’t use internet (PSN) to save them?
ANY HELP!!!!
Lewis Jenkins - Antwoord
hope you already solve this issue, but if not, there’s a backup option to save or backup them to a USB drive (thumb drive)
Rodrigo Vasquez -
Does the ps4 slim hard drive fit in a ps4 pro
Jerm Salinas - Antwoord
Yes the slim hard drive fits into the pro
Curtis Craggs -
Is there a known capacity limit, or will anything that fits in the slot work?
Juan Cascante - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 88
Afgelopen 30 dagen: 436
Altijd: 36,981
