Deze vertaling geeft mogelijk niet de meest recente updates van de bronhandleiding weer. Help ons met het updaten van de vertaling of bekijk de bronhandleiding.
Inleiding
本指南展示从 PlayStation 4 Pro 上移除风扇的必要步骤。这里有几个必要的步骤来完成此事,以及一些回导致保修失效的拆解。移除风扇需要拆解大部分 PS4 Pro。
Wat je nodig hebt
要重新组装设备,请按相反的顺序操作。
要重新组装设备,请按相反的顺序操作。
109 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
80%
Patrick Zhang helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
13 opmerkingen
Danke für die Anleitung. hat alles super geklappt. Bloß beim letzten Schritt ist die Schraube vom Lüfter nicht oben links sondern unten rechts. Mfg
Thanks for the guide. Very comprehensive.
I’m clueless with electronics but my PS4 was on its death throes with overheating. I read this guide and watched the video (coffee break included) and got to work. The only trouble I had was that my husband (he’s a good guy normally) decided to help and used too big pliers and broke the connector between the power supply and PS4. Ok, so 5 days wait for replacement. I replaced the fan, thermal paste, and pads and put it back together (shaking like a leaf in a hurricane). It’s quiet and works thanks to ifixit.com. Thank you so much!
This was super helpful! For the power supply, I was trying to pull at the socket the cable was plugged into (same color plastic). I think it would have worked better just wiggling the cable.
Also, T8 worked fine, but putting it back together, I noticed T9 was better fit, so if you have a T9, use that instead. After cleaning and repasting, it’s so much quieter. Thanks!
