Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Follow this guide to replace the power supply on your Sony Playstation 4.
  1. Flip the PS4 upside-down with the back side facing towards you.
    • Flip the PS4 upside-down with the back side facing towards you.
  2. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws. Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws. Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. Remove the four 7.2 mm Torx security screws on the back of the PS4. Remove the four 7.2 mm Torx security screws on the back of the PS4.
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. Use your thumbs to lift the lower case up and off the PS4. The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard. Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
  7. Remove three 9.7 mm Torx security screws. Remove two 41 mm Phillips screws and brackets.
    • Remove three 9.7 mm Torx security screws.
    • Remove two 41 mm Phillips screws and brackets.
  8. Lift the power supply straight up and out of the PS4. The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to get it free. During reassembly, ensure the prongs are aligned, then press the power supply into place.
    • Lift the power supply straight up and out of the PS4.
    • The power supply is held firmly in place by prongs on the left side. It may take multiple attempts to get it free.
    • During reassembly, ensure the prongs are aligned, then press the power supply into place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sam Omiotek
19.299 Reputatie
136 handleidingen geschreven
iFixit Lid van iFixit
Community
134 Leden
15.616 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 35
Afgelopen 30 dagen: 112
Altijd: 133
