Inleiding
If you are having an issue with the motherboard (or any of its ports: HDMI, USB, etc.) and need to replace it, this is the guide for you. Be aware that any replacement or teardown beyond the hard drive voids the Sony warranty
Removing the motherboard separates the original thermal paste between the processor and the heat sink. Before you reassemble your device, reapply a new layer of thermal paste. Follow this guide to learn how.
Wat je nodig hebt
Disconnect the ribbon wire from the optical drive by pressing down on the metal release tab and gently pulling the ribbon wire. This should not require force.
Disconnect the same ribbon wire from the motherboard; making sure you're pressing down on the metal release tab and gently pulling the ribbon wire.
194 andere personen hebben deze handleiding voltooid.
17 opmerkingen
Regarding the three wire plug in step 20 - is there a good way to repair this piece if, say, you pulled the wires out of the connector by accident? is there a place to get a replacement part?
I have tried to replace the hdmi port however being somewhat of an idiot I slipped and knocked off onto the little black squares just behind the port on the left hand side. Does anyone know what these are?
contacts of the motherboard
You may be talking about capacitors that are critically important for the unit to function.
South30 -
