Ga door naar hoofdinhoud
PlayStation 4 Hard Drive Replacement
Wat je nodig hebt
  1. PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: stap 1, afbeelding 1 van 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: stap 1, afbeelding 2 van 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive cover: stap 1, afbeelding 3 van 3
    • Grip the PS4 with both hands along the gap in the top cover.
    • Push the glossy side of the top cover with your thumbs until it pops to the side.
    • Lift the glossy top cover up and back to remove it from the PS4.
  2. PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket screw: stap 2, afbeelding 1 van 2 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket screw: stap 2, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the hard drive bracket to the enclosure.
  3. PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: stap 3, afbeelding 1 van 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: stap 3, afbeelding 2 van 3 PlayStation 4 Hard Drive Replacement, Remove the hard drive bracket: stap 3, afbeelding 3 van 3
    • Pull the hard drive bracket out of the enclosure.
    • Be careful not to drop the hard drive. The internal components are fragile and are susceptible to damage by sudden shock.
  4. PlayStation 4 Hard Drive Replacement, Remove the hard drive: stap 4, afbeelding 1 van 2 PlayStation 4 Hard Drive Replacement, Remove the hard drive: stap 4, afbeelding 2 van 2
    • Remove the two 7.2 mm screws from the right side of the hard drive tray.
  5. PlayStation 4 Hard Drive Replacement: stap 5, afbeelding 1 van 2 PlayStation 4 Hard Drive Replacement: stap 5, afbeelding 2 van 2
    • Remove the two 7.2 mm screws from the left side of the hard drive tray.
  6. PlayStation 4 Hard Drive Replacement: stap 6, afbeelding 1 van 2 PlayStation 4 Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Remove the hard drive from the hard drive tray.
Conclusie
You will need to reinstall the PS4 operating system after you replace your hard drive. Follow Sony’s instructions to initialize your PS4 and reinstall system software.
219 andere personen hebben deze handleiding voltooid.
Sam Omiotek
72.839 Reputatie
288 handleidingen geschreven
12 opmerkingen
This article needs to be vetted. There is a very specific type of hard drive needed for this machine. Also, the machine will need to be backed up to either the PS Network(for PS Plus members) or a removable storage device. Additionally, the latest system update must be available after the new hard drive is installed. Below is an excellent article for this procedure.
http://www.ign.com/wikis/playstation-4/H...
Kenneth Stockman - Antwoord
can I take out my 500 gig and put in a 1 tb or no ?
Phil manwarren - Antwoord
Hey Phil,
Yes, you can. I have successfully replaced the original hard drive with a 2TB hard drive I purchased. Just make sure you buy the correct type of hard drive. I recommend using the article Kenneth has linked above in the comment section: http://www.ign.com/wikis/playstation-4/H...
I backed up my saved data on the PS network instead of using an external hard drive and that worked great.
Enjoy the extra storage!
Joel Praino -
Yes you can upgrade to 1TB or even bigger. Last PS4 firmware update was in august, and it supports storage up to 4TB. You can also use bigger storage but it may result in error.
You can update 2.4-internal HDD or use something like Nyko data bank to use 3.5 inch drives. Also external hard drives is an option, but in order to use them you will need to install the software and games on it.
ps4 hard drives:
http://hddmag.com/2016/07/top-7-best-ps4...
http://www.ryli.net/ps4-hard-drive-guide...
janis kalnins - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 32
Afgelopen 7 dagen: 296
Afgelopen 30 dagen: 1,446
Altijd: 169,649
