Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
PlayStation 3 Wi-Fi/Bluetooth Board Replacement
Wat je nodig hebt
  1. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Smart Plate: stap 1, afbeelding 1 van 2 PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Smart Plate: stap 1, afbeelding 2 van 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 3, afbeelding 1 van 3 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 3, afbeelding 2 van 3 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 3, afbeelding 3 van 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 4, afbeelding 1 van 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Top Cover: stap 5, afbeelding 1 van 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 6, afbeelding 1 van 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Memory Card Reader: stap 7, afbeelding 1 van 1
    • Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
  8. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 8, afbeelding 1 van 2 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 8, afbeelding 2 van 2
    • Lift the memory card reader out of the PS3 enough to access its cable.
    • Flip up the retaining flap on the memory card reader ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the ribbon cable out of its socket.
    • Remove the memory card reader from the PS3.
  9. PlayStation 3 Wi-Fi/Bluetooth Board Replacement, Wi-Fi/Bluetooth Board: stap 9, afbeelding 1 van 1
    • If necessary, peel the memory card reader ribbon cable off the Wi-Fi/Bluetooth board.
  10. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 10, afbeelding 1 van 1
    • Use the flat end of a spudger to pry the Wi-Fi antenna connector up from its socket on the Wi-Fi/Bluetooth board.
  11. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 11, afbeelding 1 van 2 PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 11, afbeelding 2 van 2
    • Use your fingernail to flip up the retaining flap on the Wi-Fi/Bluetooth ribbon cable socket.
    • Pull the Wi-Fi/Bluetooth ribbon cable out of its socket.
  12. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 12, afbeelding 1 van 1
    • Remove the four 9 mm Phillips screws securing the Wi-Fi/Bluetooth board to the chassis.
  13. PlayStation 3 Wi-Fi/Bluetooth Board Replacement: stap 13, afbeelding 1 van 1
    • Remove the Wi-Fi/Bluetooth board from the PS3, minding any cables that may get caught.
Conclusie
25 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Note: Only the first 2 generations of PS3 fats have removable Wifi/BT cards. If you have a third generation fat (VER-100 motherboard or later) the Wifi/BT chips are integrated into the board and thereby NOT removable.
Kevin Kwan - Antwoord
does anybody know how many pins there are on the data ribbon / flex cable of the Wifi / Bluetooth board and Card Reader in the 60gb Model? It would be a great help! Thanx
yasien teladia - Antwoord
I have a PS3 Slim 2501b can I still use this technique to change my Bluetooth
Kathleen Pereira - Antwoord
No you can't
J P -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 14
Afgelopen 7 dagen: 103
Afgelopen 30 dagen: 501
Altijd: 114,789
