Ga door naar hoofdinhoud
Inleiding
You can use this method if you can't eject the stuck disk by the eject button and the eject hole. The PS3 slim on this video is model CECH-300X.
Full video you can see here:
More info about disassembling, you can find in PlayStation 3 Slim Teardown
Video overzicht
  1. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. Unscrew the three screws. To remove Blu Ray unit shell you must open two plates that are on the left and right side. Unscrew the three screws. To remove Blu Ray unit shell you must open two plates that are on the left and right side. Unscrew the three screws. To remove Blu Ray unit shell you must open two plates that are on the left and right side.
    • Unscrew the three screws. To remove Blu Ray unit shell you must open two plates that are on the left and right side.
  3. First remove the spindle disc magnet. Now use plastic tool and slowly extrude the disk from inside. First remove the spindle disc magnet. Now use plastic tool and slowly extrude the disk from inside. First remove the spindle disc magnet. Now use plastic tool and slowly extrude the disk from inside.
    • First remove the spindle disc magnet. Now use plastic tool and slowly extrude the disk from inside.
  4. In this case we have ... 4x disks. :) .
    • In this case we have ... 4x disks. :)
    • Did you do it successfully?
  5. Test the console before assembling. And don't forget to put the spindle disc magnet. Test the console before assembling. And don't forget to put the spindle disc magnet.
    • Test the console before assembling. And don't forget to put the spindle disc magnet.
Conclusie
14 andere personen hebben deze handleiding voltooid.
ZFix
166.755 Reputatie
305 handleidingen geschreven
Master Techs Lid van Master Techs
Community
288 Leden
820 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 2
Afgelopen 7 Dagen: 11
Afgelopen 30 Dagen: 95
Altijd: 12,879
