Inleiding
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
More info about disassembling, you can find in
Wat je nodig hebt
Video overzicht
Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
Remove the 4 Phillips screws at each corner of the laser mechanism.
Then remove the mechanism.
What is the part number for the 4 screws that secure the laser deck and also the part number for the 4 rubber shock absorbers where the screws go into?
16 andere personen hebben deze handleiding voltooid.
Één opmerking
Do you know what the part number is for the deck? I don’t want to buy the wrong one. Thanks.
What is the part number for the plastic caps that hide the screws?
There's rubber caps and plastic caps that you have to remove to access the screws.
Byron Arriola - Antwoord
Model 2504B : You have to remove the hard drive first in order to remove the case.
Stephane Dannebey - Antwoord
