Inleiding
PlayStation 3 - How to replace Laser Lens and Mechanism (Laser Deck).
Please SUBSCRIBE to my channel ツ
More info about disassembling, you can find in
PlayStation 3 Slim Teardown
Video overzicht
  1. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case. Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
    • Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
  2. Remove Power Supply. Remove Power Supply. Remove Power Supply.
    • Remove Power Supply.
  3. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive. Separate cables, unscrew the screw and remove the Blu Ray drive.
    • Separate cables, unscrew the screw and remove the Blu Ray drive.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  5. Disassemble the upper metal shield. . Please SUBSCRIBE to my channel  ツ
  6. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles. Remove the two very small phillips screws in each lower corner referenced by the red circles.
    • Remove the two very small phillips screws in each lower corner referenced by the red circles.
  7. Be careful with flex cables. Be careful with flex cables. Be careful with flex cables.
    • Be careful with flex cables.
  8. Now you can remove the Laser Deck. Now you can remove the Laser Deck. Now you can remove the Laser Deck.
    • Now you can remove the Laser Deck.
  9. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers. Transfer two flex cables and 2x rubbers.
    • Transfer two flex cables and 2x rubbers.
  10. You can test the console before full assembling. . Did you do it successfully?
Conclusie
12 andere personen hebben deze handleiding voltooid.
ZFix
162.554 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
280 Leden
784 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 4
Afgelopen 7 Dagen: 88
Afgelopen 30 Dagen: 223
Altijd: 16,102
