Inleiding
If you want to replace the fan or clean the fan system - video tutorial:
Please SUBSCRIBE to my channel ツ
Video overzicht
  1. Disconnect the fan cable and remove the nine screws from the bottom side. Disconnect the fan cable and remove the nine screws from the bottom side. Disconnect the fan cable and remove the nine screws from the bottom side.
    • Disconnect the fan cable and remove the nine screws from the bottom side.
  2. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield. Remove the two heat sink clamps and bottom shield, then gently separate  the motherboard off the top shield.
    • Remove the two heat sink clamps and bottom shield, then gently separate the motherboard off the top shield.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Remove the four Phillips screws and lift the top shield. Remove the four Phillips screws and lift the top shield. Remove the four Phillips screws and lift the top shield.
    • Remove the four Phillips screws and lift the top shield.
Conclusie
6 andere personen hebben deze handleiding voltooid.
ZFix
162.930 Reputatie
304 handleidingen geschreven
Master Techs Lid van Master Techs
Community
281 Leden
792 handleidingen geschreven
Awesome guide. Thank you so much. I did it, but now I just wonder what that white stuff was when I removed the motherboard. I think it's that thermal stuff people have been talking about and I suppose I have to replace that. I also hope that it's the fan that is what's causing my PS3 to say that it's overheating and shut off. I'm so glad you guys posted this. Great job. I rather do it myself than pay Sony an arm and a leg. Cheers!
chetacheez - Antwoord
This is CPU / GPU thermal paste / compound. I recommend you Arctic MX-2, MX-4. It is very good and not expensive.
ZFix -
Weergavestatistieken:
Afgelopen 24 Uren: 3
Afgelopen 7 Dagen: 27
Afgelopen 30 Dagen: 85
Altijd: 8,026
