Ga door naar hoofdinhoud
PlayStation 3 Control Board Replacement
Wat je nodig hebt
  1. PlayStation 3 Control Board Replacement, Smart Plate: stap 1, afbeelding 1 van 2 PlayStation 3 Control Board Replacement, Smart Plate: stap 1, afbeelding 2 van 2
    • Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
    • The screw cover may be underneath a warranty sticker. This sticker will change appearance, and show "VOID" after it has been removed.
  2. PlayStation 3 Control Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
  3. PlayStation 3 Control Board Replacement: stap 3, afbeelding 1 van 3 PlayStation 3 Control Board Replacement: stap 3, afbeelding 2 van 3 PlayStation 3 Control Board Replacement: stap 3, afbeelding 3 van 3
    • Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
  4. PlayStation 3 Control Board Replacement: stap 4, afbeelding 1 van 1
    • Be sure to keep track of the small metal bracket loosely held in the top cover, if equipped.
  5. PlayStation 3 Control Board Replacement, Top Cover: stap 5, afbeelding 1 van 1
    • Remove the following seven screws:
    • Six 52 mm Phillips screws
    • One 30 mm Phillips screw
  6. PlayStation 3 Control Board Replacement: stap 6, afbeelding 1 van 1
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Remove the top cover.
    • There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
  7. PlayStation 3 Control Board Replacement, Control Board: stap 7, afbeelding 1 van 2 PlayStation 3 Control Board Replacement, Control Board: stap 7, afbeelding 2 van 2
    • Use your fingernail to flip up the retaining flap on the control board ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the control board ribbon cable out of its socket.
  8. PlayStation 3 Control Board Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 12 mm Phillips screws securing the control board to the lower case.
  9. PlayStation 3 Control Board Replacement: stap 9, afbeelding 1 van 1
    • Remove the control board from the lower case.
Conclusie
21 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
I don't have the same ps3 as in the tutorial and my control board is broken. What can i do now?
McGarvey - Antwoord
Could anyone tell me if they would have the connection pin of this board, as I would like to fit it into a motherboard.
Allan Fabian Santos Souza - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 77
Afgelopen 30 dagen: 205
Altijd: 52,143
