Inleiding
In the course of servicing your PS3, you may wish to open the black plastic power supply to inspect the components. If like me you can’t immediately figure out how to open the power supply, this guide is for you.
This guide begins with a complete teardown of Playstation 3. After you finish steps 1-7 of this guide, by removing the power supply, you may skip to step 12 to finish the disassembly of the power supply.
Wat je nodig hebt
Using fingernail, or spudger, remove the cover.
Remove PH1 screw
Pull HDD out.
Remove sticker an underlying rubber tab
Remove the T8 security screw
Pull cover towards you to remove
Remove the 6 long medium screws
Remove the medium medium screw. This screw is conveniently marked with an S if you forget what goes where.
Use a finger to press the tab next to the medium length screw and lift. The case pivots on the front.
When putting back together, place the front edge and rotate back. The screws will pop everything back in place.
Remove M screw
Remove medium medium screws
Remove long M screws
Using something non-conductive, lift this corner up to make removal easier.
Pull straight up to remove the power supply.
Remove the short medium screws
Remove the ground screw
Remove the heatsink screws and braces
Lift the front to remove
Unscrew the M screws and unplug the board battery. Your PS3 now does not know the date and time.
I messed up when I put it back together. The shield goes under the top half of the HDD cage.
Lift this side of the HDD cage and wiggle it. The pins can be tricky.
Remove the shield over the USB and WiFi controller
Remove the USB and WiFi controller. It lifts straight up. Remove the white tape.
Lift from this side to remove the motherboard shield.
The motherboard lifts right out
After completing step 7 of that guide, remove the power supply and continue from this step.
Remove 3 Phillips screws from the bottom of the power supply. These hold together the upper and lower halves of the plastic power supply case.
After removing the three screws, the power supply's plastic case is still secured by six plastic hooks and latches around the perimeter seam. It takes some doing, but if you carefully pry around the edges you can eventually release all of these without breaking any plastic.
Even if you do break some of the plastic latches, the case is still held together securely by the three screws that you previously removed.
The circuit board is now revealed in all its glory.
Inspect for bulging or leaking electrolytic capacitors, or obviously burned components.
A small tubular fuse is soldered into the circuit board near the left edge of the photo. Be sure to replace it if there is no continuity.
