Ga door naar hoofdinhoud
PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement
Wat je nodig hebt
  1. Voorzichtig: stappen 1-7 komen van een handleiding die in bewerking is.
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  2. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 2, afbeelding 1 van 1
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  3. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 3, afbeelding 1 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 3, afbeelding 2 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 3, afbeelding 3 van 3
    • Remove the five visible feet from the bottom of the device using a spudger.
  4. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 4, afbeelding 1 van 2 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 4, afbeelding 2 van 2
    • Remove the sticker and then remove the 6th foot.
  5. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 5, afbeelding 1 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 5, afbeelding 2 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 5, afbeelding 3 van 3
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  6. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 6, afbeelding 1 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 6, afbeelding 2 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 6, afbeelding 3 van 3
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
    It took force to open it, but i broke a plastic pin where the screws enter
    Vasco Mateus - Antwoord
    You can use a pick to get the thin edge up without breaking anything.
    Mira Mogzec - Antwoord
  7. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 7, afbeelding 1 van 1
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  8. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement, Optical Drive: stap 8, afbeelding 1 van 2 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement, Optical Drive: stap 8, afbeelding 2 van 2
    • Locate the optical drive on the motherboard.
  9. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 9, afbeelding 1 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 9, afbeelding 2 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 9, afbeelding 3 van 3
    • Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
  10. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 10, afbeelding 1 van 1
    • Locate the three ribbons that are attached to the motherboard.
    • Note: These ribbons are different sizes: one large, one medium and one small sized ribbon.
  11. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 11, afbeelding 1 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 11, afbeelding 2 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 11, afbeelding 3 van 3
    • Using tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon to lift the black tab up on either side.
    • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  12. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 12, afbeelding 1 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 12, afbeelding 2 van 3 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: stap 12, afbeelding 3 van 3
    • Gently lift the optical drive away from the motherboard.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Jared Hirata
880 Reputatie
7 handleidingen geschreven
Cal Poly, Team 17-4, Regan Spring 2013 Lid van Cal Poly, Team 17-4, Regan Spring 2013
CPSU-REGAN-S13S17G4
3 Leden
28 handleidingen geschreven
Één opmerking
I think that if the entire disc drive, assembled with a simple click in connection, would be much easier and faster.
Fernando Salazar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 5,464
