Inleiding
This guide will walk you through step-by-step on how to properly remove and install the IR sensor in the PlayStation 2 Slimline.
    • Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
  1. Locate the six feet on the bottom of the PS2.
    • Locate the six feet on the bottom of the PS2.
    • Five of the feet are in plain sight and one of the feet is located under the black void sticker on the bottom of the device.
    • IMPORTANT: Removing the black VOID sticker will void the warranty of this device. Proceed at your own risk
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or even the screw should be in plain sight.
  2. Use a spudger, flathead screwdriver, or fingernail to pry the five visible feet from the bottom of the device. Use a spudger, flathead screwdriver, or fingernail to pry the five visible feet from the bottom of the device. Use a spudger, flathead screwdriver, or fingernail to pry the five visible feet from the bottom of the device.
    • Use a spudger, flathead screwdriver, or fingernail to pry the five visible feet from the bottom of the device.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. The sixth foot is located under the black VOID sticker.  Remove the sticker before  removing the foot underneath. The sixth foot is located under the black VOID sticker.  Remove the sticker before  removing the foot underneath.
    • The sixth foot is located under the black VOID sticker. Remove the sticker before removing the foot underneath.
  5. After all of the feet have been removed, locate the six 4.0mm screws on the base of the PS2. After all of the feet have been removed, locate the six 4.0mm screws on the base of the PS2.
    • After all of the feet have been removed, locate the six 4.0mm screws on the base of the PS2.
  6. Use a #1 Phillips screwdriver to unscrew all six 4.0mm screws from the base of the PS2. Use a #1 Phillips screwdriver to unscrew all six 4.0mm screws from the base of the PS2. Use a #1 Phillips screwdriver to unscrew all six 4.0mm screws from the base of the PS2.
    • Use a #1 Phillips screwdriver to unscrew all six 4.0mm screws from the base of the PS2.
  7. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
    • Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
  8. If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  9. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
    • Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jared Hirata
495 Reputatie
7 handleidingen geschreven
Cal Poly, Team 17-4, Regan Spring 2013 Lid van Cal Poly, Team 17-4, Regan Spring 2013
CPSU-REGAN-S13S17G4
3 Leden
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 1,408
