Ga door naar hoofdinhoud
PlayStation 2 Slimline Optical Drive Replacement
Wat je nodig hebt
  1. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: stap 1, afbeelding 1 van 3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: stap 1, afbeelding 2 van 3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: stap 1, afbeelding 3 van 3
    • Remove the rubber feet on two of the screw covers on the bottom of the console.
    • Remove the screw covers and the screws themselves.
    • Caution: One of the screws is underneath the "Do not void" seal
  2. PlayStation 2 Slimline Optical Drive Replacement: stap 2, afbeelding 1 van 2 PlayStation 2 Slimline Optical Drive Replacement: stap 2, afbeelding 2 van 2
    • If all screws are removed.
    • Use a metal spunger to open the chassis
  3. PlayStation 2 Slimline Optical Drive Replacement: stap 3, afbeelding 1 van 3 PlayStation 2 Slimline Optical Drive Replacement: stap 3, afbeelding 2 van 3 PlayStation 2 Slimline Optical Drive Replacement: stap 3, afbeelding 3 van 3
    • Slip the three cables out of the sockets.
    • Use a PH01 screwdriver to remove the four screws securing the optical drive
    • Lift up the optical drive and remove the duct tape under the flex cable.
    • Now the optical drive is free and ready for replacement
Conclusie
16 andere personen hebben deze handleiding voltooid.
tlroesner
1.864 Reputatie
4 handleidingen geschreven
3 opmerkingen
How is it that this guide says difficult and the other PS2 drive replacement on here says easy?
Mark - Antwoord
it really depends on your level of skill/experience.
Damien Simons -
How many different versions of drive is there for the slim model? When you go to replace it, do you just compare the model number on the laser?
Trevor V - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 91
Altijd: 22,129
