Onderdelen
Geen onderdelen opgegeven.
Disconnect all cables from the console and flip the unit over to reveal its base.
Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
Remove the 2.4 mm screw located in between the controller ports using a #1 Phillips screwdriver.
20 andere personen hebben deze handleiding voltooid.
2 Opmerkingen
نرجو اضافة اللغة العربية
you can choose the translate mode in google chrome and it will be automatically translated for you hill climb racing
