Ga door naar hoofdinhoud
PlayStation 2 Slimline IR Sensor Replacement
Wat je nodig hebt
  1. PlayStation 2 Slimline IR Sensor Replacement, Outer Shell: stap 1, afbeelding 1 van 1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline IR Sensor Replacement: stap 2, afbeelding 1 van 3 PlayStation 2 Slimline IR Sensor Replacement: stap 2, afbeelding 2 van 3 PlayStation 2 Slimline IR Sensor Replacement: stap 2, afbeelding 3 van 3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline IR Sensor Replacement: stap 3, afbeelding 1 van 3 PlayStation 2 Slimline IR Sensor Replacement: stap 3, afbeelding 2 van 3 PlayStation 2 Slimline IR Sensor Replacement: stap 3, afbeelding 3 van 3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline IR Sensor Replacement: stap 4, afbeelding 1 van 3 PlayStation 2 Slimline IR Sensor Replacement: stap 4, afbeelding 2 van 3 PlayStation 2 Slimline IR Sensor Replacement: stap 4, afbeelding 3 van 3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline IR Sensor Replacement, IR Sensor: stap 5, afbeelding 1 van 1
    • Locate the IR sensor at the front, right corner of the unit.
  6. PlayStation 2 Slimline IR Sensor Replacement: stap 6, afbeelding 1 van 1
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  7. PlayStation 2 Slimline IR Sensor Replacement: stap 7, afbeelding 1 van 1
    • Gently lift and remove the IR Sensor from its designated slot.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Thomas Sullivan
3.900 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 70
Altijd: 6,737
