Inleiding
Remove and replace your PlayStation 2's power board.
Onderdelen
Geen onderdelen opgegeven.
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
Lift and remove the optical disc drive straight up out of the bottom case.
24 andere personen hebben deze handleiding voltooid.
3 Opmerkingen
Where do I buy the new Power Board?
Where can you buy a new power board?
