Ga door naar hoofdinhoud
PlayStation 2 Optical Disc Drive Laser Assembly Replacement
Wat je nodig hebt
  1. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: stap 1, afbeelding 1 van 3 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: stap 1, afbeelding 2 van 3 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Top Cover: stap 1, afbeelding 3 van 3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    Vraag FixBot
    Voeg opmerking toe
  2. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: stap 2, afbeelding 1 van 1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
    Vraag FixBot
    Voeg opmerking toe
  3. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: stap 3, afbeelding 1 van 1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
    Vraag FixBot
    Voeg opmerking toe
  4. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: stap 4, afbeelding 1 van 2 PlayStation 2 Optical Disc Drive Laser Assembly Replacement: stap 4, afbeelding 2 van 2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    Vraag FixBot
    Voeg opmerking toe
  5. PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: stap 5, afbeelding 1 van 2 PlayStation 2 Optical Disc Drive Laser Assembly Replacement, Optical Disc Drive Laser Assembly: stap 5, afbeelding 2 van 2
    • Remove the four 6.4 mm Phillips screws securing the top lid of the optical disc drive.
    • Lift and remove the lid from the optical disc drive.
    Vraag FixBot
    Voeg opmerking toe
  6. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 7.2 mm Phillips black screws securing the metal silver rails that hold the laser in place.
    Vraag FixBot
    Voeg opmerking toe
  7. PlayStation 2 Optical Disc Drive Laser Assembly Replacement: stap 7, afbeelding 1 van 1
    • Use your fingernail to flip up the retaining flap on the optical disc drive laser ribbon cable.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
    • Pull the optical disc drive laser ribbon cable straight away and out of its socket.
    • If you maneuver the unscrewed ends of the metal rails upwards, the laser will slide out.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
38 andere personen hebben deze handleiding voltooid.
jwyoung
3.199 Reputatie
5 handleidingen geschreven
Cal Poly, Team 19-1, Maness Fall 2009 Lid van Cal Poly, Team 19-1, Maness Fall 2009
CPSU-MANESS-F09S19G1
4 Leden
35 handleidingen geschreven
8Gids Commentaar
just did the laser replacement, however the playstation still identifies "no data" when game is inserted. it says "reading disk" for a few seconds then nothing else happens. thought?
Danyal Fatmi - Antwoord Deel
Have you removed the security solder blob? All new Lenses have this somewhere in the circuitry.
Carlos Bragatto - Antwoord Deel
Number 1 Ifixit the class world,
Mohsen - Antwoord Deel
I noticed that many times when you replace a lens it throws of the rotary motor. Some ps2 consoles have only 1 hex adjustment yet others have 2. If you have the covers off and just replaced the lenses you should always plug it back in w/ the top off still and adjust it until you see the disc spinning rapidly and laser is moving back and forth. Another way for calibrating is to remove said disc and if lens and ribbon move all the way forward and all the way back 3 or more times then you are almost done. At that point plug in tv chord and place in a disc if the PlayStation 2 logo comes on and disappears in less than 3 seconds carefully replace all parts and your good to go.
Raymond - Antwoord Deel
Could you please add the parts you would need to replace this to the parts portion.
Nice guide by the way.
Alexander Wiand - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 110
Afgelopen 30 dagen: 645
Altijd: 93,754
