Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the camera over so the bottom of the camera is facing you.
Slide the bottom cover in the direction of the arrow to open it.
Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
Remove the four 4.7 mm screws on the left side of the camera.
Remove the four 4.7 mm screws on the opposite side of the camera.
Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
Once the bottom of the inner camera is pulled out, pull the device out completely.
