Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide will teach the reader how to install a new case of the camera. If the case on the camera gets cracked or is starting to come apart, this guide will help to replace it with a new case.
Wat je nodig hebt
Unless otherwise stated, use a phillips #00 screwdriver to remove screws.
Remove the two 4.70mm screws in the bottom of the plastic casing.
