Ga door naar hoofdinhoud
Plantronics CS50 Headset System Reset
    1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: stap 1, afbeelding 1 van 2 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: stap 1, afbeelding 2 van 2
      • Press and hold both the call control button and the listening volume/mute button for five seconds.
      • When the talk indicator light blinks, release both buttons.
      Vraag FixBot
      Voeg opmerking toe
    2. Plantronics CS50 Headset System Reset: stap 2, afbeelding 1 van 1
      • Press the call control button again.
      Vraag FixBot
      Voeg opmerking toe
    3. Plantronics CS50 Headset System Reset: stap 3, afbeelding 1 van 2 Plantronics CS50 Headset System Reset: stap 3, afbeelding 2 van 2
      • Unplug the base unit's power source for ten seconds.
      • Plug the power source back in.
      Vraag FixBot
      Voeg opmerking toe
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Joe
117 Reputatie
3 handleidingen geschreven
Cal Poly, Team 17-29, Amido Spring 2012 Lid van Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Leden
83 handleidingen geschreven
4Gids Commentaar
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - Antwoord Deel
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - Antwoord Deel
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - Antwoord Deel
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 34
Altijd: 23,449
