Ga door naar hoofdinhoud
Plantronics CS50 Headset Battery Replacement
Wat je nodig hebt
    1. Plantronics CS50 Headset Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Plantronics CS50 Headset Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Plantronics CS50 Headset Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Flip the headset face down.
      • Squeeze both sides of the battery cover.
      • While squeezing, pull the cover up slowly to remove it.
      Vraag FixBot
      Voeg opmerking toe
    2. Plantronics CS50 Headset Battery Replacement: stap 2, afbeelding 1 van 3 Plantronics CS50 Headset Battery Replacement: stap 2, afbeelding 2 van 3 Plantronics CS50 Headset Battery Replacement: stap 2, afbeelding 3 van 3
      • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order
Yuliya Levitskaya
77 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-29, Amido Spring 2012 Lid van Cal Poly, Team 17-29, Amido Spring 2012
CPSU-AMIDO-S12S17G29
4 Leden
83 handleidingen geschreven
2Gids Commentaar
I created the article https://de.ifixit.com/Artikel/Battery_Pl... for a Silvercrest bluetooth transmitter, but I was not able to change the needed parts of this howto to link to that article.
anton2 - Antwoord Deel
I replaced the battery with a new battery, I cleaned all the connectors and I reset the base and the headset is still not working
Lee kathryn lucas - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 49
Altijd: 8,321
