Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
Pull the grip through the opening.
The grip is connected in the middle and is one piece.
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
While pulling in the metal ring on the fitting, pull the macroline out.
Use 1/8" allen wrench to remove screw behind regulator.
Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
Use a prying tool or tweezers to gently remove the connection from the board. It is the connection with 2 black and 2 red wires.
Pull the wire through the opening.
Use 5/64" allen key to remove each screw from eye covers (Located on both sides of the paintball marker.)
Pull off eye covers. (Located on both sides of the paintball marker.)
Gently pull out the two eyes, one on each side of the paintball marker.
