Ga door naar hoofdinhoud
Planet Eclipse Etha Solenoid Replacement
Wat je nodig hebt
  1. Planet Eclipse Etha Solenoid Replacement, Regulator: stap 1, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement, Regulator: stap 1, afbeelding 2 van 2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Planet Eclipse Etha Solenoid Replacement: stap 2, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement: stap 2, afbeelding 2 van 2
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: stap 3, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement, Battery and Grip Panels: stap 3, afbeelding 2 van 2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Planet Eclipse Etha Solenoid Replacement: stap 4, afbeelding 1 van 1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Planet Eclipse Etha Solenoid Replacement: stap 5, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Planet Eclipse Etha Solenoid Replacement, Frame: stap 6, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement, Frame: stap 6, afbeelding 2 van 2
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Planet Eclipse Etha Solenoid Replacement: stap 7, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement: stap 7, afbeelding 2 van 2
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Planet Eclipse Etha Solenoid Replacement: stap 8, afbeelding 1 van 1
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
  9. Planet Eclipse Etha Solenoid Replacement, Solenoid: stap 9, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement, Solenoid: stap 9, afbeelding 2 van 2
    • Remove the two black hex bolts that connect the solenoid mount to the body.
    • Use the 5/64" Allen Key to rotate each screw counter clockwise.
  10. Planet Eclipse Etha Solenoid Replacement: stap 10, afbeelding 1 van 2 Planet Eclipse Etha Solenoid Replacement: stap 10, afbeelding 2 van 2
    • Remove the two Phillips head screws that connect the solenoid to its mount.
    • Use a Phillip's head screwdriver and rotate each screw counter clockwise.
    • Do not attempt to dismantle the solenoid. Intentionally dismantling or tampering with the solenoid voids the manufacturer’s warranty.
Conclusie
Austin Eslinger
110 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-42, Amido Fall 2014 Lid van Cal Poly, Team 10-42, Amido Fall 2014
CPSU-AMIDO-F14S10G42
5 Leden
7 handleidingen geschreven
3 opmerkingen
Watis the price on etha solenoid, where can i get one , l ma staying in SA, myne is leaking ear,email ratgonefishing @gmail. Com
Roelof Koekemoer - Antwoord
Hi my etha solenoid leaks ear,where do l get one,wats the price,i m staying in SA
Hello if it’s leaking try to lubricate your O-rings and switch out the filter, these can be very expensive from $55-$99 they don’t Make this model anymore so it’s very hard to find
Eddie -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 2,423
