Inleiding
Removing the grip panels allows you to change the battery and allows you to remove the frame, which gives access to more parts of the marker.
Wat je nodig hebt
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
Één andere persoon heeft deze handleiding voltooid.
