Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
With force, pull upwards.
Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
Repeat on the opposite side and the headband will be released.
