Ga door naar hoofdinhoud
Pioneer Steel Wheels Folding Hinges Replacement
Wat je nodig hebt
  1. Pioneer Steel Wheels Folding Hinges Replacement, Headband: stap 1, afbeelding 1 van 2 Pioneer Steel Wheels Folding Hinges Replacement, Headband: stap 1, afbeelding 2 van 2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Folding Hinges Replacement: stap 2, afbeelding 1 van 2 Pioneer Steel Wheels Folding Hinges Replacement: stap 2, afbeelding 2 van 2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Folding Hinges Replacement: stap 3, afbeelding 1 van 3 Pioneer Steel Wheels Folding Hinges Replacement: stap 3, afbeelding 2 van 3 Pioneer Steel Wheels Folding Hinges Replacement: stap 3, afbeelding 3 van 3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: stap 4, afbeelding 1 van 2 Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: stap 4, afbeelding 2 van 2
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  5. Pioneer Steel Wheels Folding Hinges Replacement: stap 5, afbeelding 1 van 2 Pioneer Steel Wheels Folding Hinges Replacement: stap 5, afbeelding 2 van 2
    • While apart, remove the screw from the headphone.
  6. Pioneer Steel Wheels Folding Hinges Replacement: stap 6, afbeelding 1 van 2 Pioneer Steel Wheels Folding Hinges Replacement: stap 6, afbeelding 2 van 2
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  7. Pioneer Steel Wheels Folding Hinges Replacement: stap 7, afbeelding 1 van 2 Pioneer Steel Wheels Folding Hinges Replacement: stap 7, afbeelding 2 van 2
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
Conclusie
Garrett Leung
955 Reputatie
8 handleidingen geschreven
Cal Poly, Team 10-40, Amido Spring 2013 Lid van Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Leden
37 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 465
