Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
This guide will show you the steps to remove the aluminum plates.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the two screws on the underside of the headband with the PH0 Phillips screw driver. Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband. With force, pull upwards.
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Remove the rail-piece that is now sticking up by pulling it up and out of the headphone. Repeat on the opposite side and the headband will be released. During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. De essentiƫle toolkit
    De meest behulpzame tools in onze meest compacte kit.
    Koop nu
    Koop nu
  5. While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece. While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece.
    • While holding the base of the ear cup with one hand, insert your index finger from your other hand into the inside of the foam ear piece.
  6. With slight force, peel the foam ear pieces away from the ear cup. Make sure to pull out the foam ear pieces slowly. Pulling on them fast will tear the leather wrapping. Repeat for the opposite side if necessary.
    • With slight force, peel the foam ear pieces away from the ear cup.
    • Make sure to pull out the foam ear pieces slowly. Pulling on them fast will tear the leather wrapping.
    • Repeat for the opposite side if necessary.
  7. Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver. Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
    • Remove the three screws located on the driver cover of the ear cup with the PH0 Phillips screw driver.
  8. Pull the driver cover away from the headphone. Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • Pull the driver cover away from the headphone.
    • Do not pull the driver cover away too fast since there are wires connecting the driver to the ear cup.
    • During reassembly, make sure the two wires are pointing downward before screwing the driver back in.
  9. Remove the three screws located on the driver casing. Remove the three screws located on the driver casing. Remove the three screws located on the driver casing.
    • Remove the three screws located on the driver casing.
  10. With your thumb, push the middle of the aluminum piece outwards while holding the ear cup base with your other hand. During reassembly, make sure the aluminum plates line up with the holes for the screws. During reassembly, make sure the aluminum plates line up with the holes for the screws.
    • With your thumb, push the middle of the aluminum piece outwards while holding the ear cup base with your other hand.
    • During reassembly, make sure the aluminum plates line up with the holes for the screws.
Conclusie
Garrett Leung
892 Reputatie
8 handleidingen geschreven
Cal Poly, Team 10-40, Amido Spring 2013 Lid van Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Leden
23 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 315
