Ga door naar hoofdinhoud
Pioneer R1 LCD Display Replacement
Wat je nodig hebt
  1. Pioneer R1 LCD Display Replacement, LCD Display: stap 1, afbeelding 1 van 1
    • Insert your plastic spudger in the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 LCD Display Replacement: stap 2, afbeelding 1 van 1
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 LCD Display Replacement: stap 3, afbeelding 1 van 1
    • Remove the tape that is holding the motherboard to the display and covering the cable attachments.
    • Peel back just the end of this tape to free the front facing camera.
  4. Pioneer R1 LCD Display Replacement: stap 4, afbeelding 1 van 1
    • Remove the three 4 mm screws along the base of the motherboard with a Phillips #00 Screwdriver.
  5. Pioneer R1 LCD Display Replacement: stap 5, afbeelding 1 van 1
    • Disengage the two cable locks using your spudger or your finger nail.
    • Slide the cable free from the disengaged lock.
    • Do not pull across the cables as this may tear and permanently damage it.
  6. Pioneer R1 LCD Display Replacement: stap 6, afbeelding 1 van 2 Pioneer R1 LCD Display Replacement: stap 6, afbeelding 2 van 2
    • Insert your spudger between the LCD display and the touch screen.
    • Gently pry the LCD display from the the touchscreen by using the spudger along the edges.
    • Once disengaged, remove the LCD display from the touchscreen.
  7. Pioneer R1 LCD Display Replacement: stap 7, afbeelding 1 van 1
    • Slide a strong thin object, like a thin spudger, between the battery and the display.
    • Slide the object along the length of the battery to remove it from the display.
    • The adhesive holding the battery in place is strong and the battery is quite soft. Take care not to break open the battery.
  8. Pioneer R1 LCD Display Replacement: stap 8, afbeelding 1 van 1
    • Carefully pry off the component that is taped to the LCD display at the top of the R1.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Rosario
411 Reputatie
4 handleidingen geschreven
San Diego State, Team 1-1, Sheppard Winter 2015 Lid van San Diego State, Team 1-1, Sheppard Winter 2015
SDSU-SHEPPARD-W15S1G1
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 630
