Ga door naar hoofdinhoud
Pioneer R1 Battery Replacement
Wat je nodig hebt
  1. Pioneer R1 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert your plastic spudger into the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 Battery Replacement: stap 2, afbeelding 1 van 1
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 Battery Replacement: stap 3, afbeelding 1 van 1
    • Slide a strong thin object, like a thin spudger, between the battery and the display.
    • Slide the object along the length of the battery to remove it from the display.
    • The adhesive holding the battery in place is strong and the battery is quite soft. Take care not to break open the battery.
    • Disengage the battery cables from the motherboard.
  4. Pioneer R1 Battery Replacement: stap 4, afbeelding 1 van 1
    • Solder the black cable to the nodule labeled BAT+.
    • Solder the red cable to the nodule labeled BAT-.
    • Do not allow the solder from one nodule to touch the other, this may cause the battery to explode.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Christopher Rosario
411 Reputatie
4 handleidingen geschreven
San Diego State, Team 1-1, Sheppard Winter 2015 Lid van San Diego State, Team 1-1, Sheppard Winter 2015
SDSU-SHEPPARD-W15S1G1
3 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 792
