Ga door naar hoofdinhoud
Pioneer FH-X730BS Auxiliary Inlet Replacement
Wat je nodig hebt
  1. Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: stap 1, afbeelding 1 van 3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: stap 1, afbeelding 2 van 3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: stap 1, afbeelding 3 van 3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Auxiliary Inlet Replacement: stap 2, afbeelding 1 van 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: stap 2, afbeelding 2 van 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: stap 2, afbeelding 3 van 3
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS Auxiliary Inlet Replacement: stap 3, afbeelding 1 van 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: stap 3, afbeelding 2 van 3 Pioneer FH-X730BS Auxiliary Inlet Replacement: stap 3, afbeelding 3 van 3
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS Auxiliary Inlet Replacement, Auxiliary Inlet: stap 4, afbeelding 1 van 1
    • Here you are able to desolder the auxiliary ports from the circuit board and solder a replacement auxiliary port on.
    • The end of the soldering iron will be hot.
Conclusie
Cody Pesta
688 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 181
