Ga door naar hoofdinhoud
Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement
Wat je nodig hebt
  1. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement, Control Panel Circuit Board: stap 1, afbeelding 1 van 1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Unlatch the three plastic connectors on the top of the receiver that hold the front panel to the device casing.
  5. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 5, afbeelding 1 van 1
    • The connectors on the bottom of the device may be very stiff and could require the use of a plastic prying tool.
    • Carefully flip the device over and unlatch the three plastic connectors that hold the front panel to the bottom of the device casing.
  6. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Grip and unplug the ribbon connector that connects the front circuit board to the device.
  7. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 7, afbeelding 1 van 1
    • Unscrew the three 1/4 Phillips head screws on the back of the front circuit board.
  8. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 8, afbeelding 1 van 2 Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: stap 8, afbeelding 2 van 2
    • Grip the circuit board and slide towards the front side of the plastic casing.
    • Lift upwards to remove the circuit board from the front panel.
Conclusie
Cody Carter
1.049 Reputatie
6 handleidingen geschreven
Baylor, Team S1-G5, Johnson Spring 2018 Lid van Baylor, Team S1-G5, Johnson Spring 2018
BU-JOHNSON-S18S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 470
