Ga door naar hoofdinhoud
Pine64 PinePhone Front and Rear Camera Replacement
Wat je nodig hebt
  1. Pine64 PinePhone Front and Rear Camera Replacement, Back Cover: stap 1, afbeelding 1 van 2 Pine64 PinePhone Front and Rear Camera Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Front and Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Front and Rear Camera Replacement, Battery: stap 3, afbeelding 1 van 1
    • Using a fingernail, press into the bottom divot and remove the battery from the phone.
  4. Pine64 PinePhone Front and Rear Camera Replacement, Motherboard: stap 4, afbeelding 1 van 1
    • Use a spudger or plastic opening tool to pry off the plastic cover.
  5. Pine64 PinePhone Front and Rear Camera Replacement: stap 5, afbeelding 1 van 1
    • Use a spudger to lift the ZIF tabs and press-fit connectors free.
  6. Pine64 PinePhone Front and Rear Camera Replacement: stap 6, afbeelding 1 van 1
    • Use a spudger to lift the motherboard up and remove it from the device.
  7. Pine64 PinePhone Front and Rear Camera Replacement, Front and Rear Camera: stap 7, afbeelding 1 van 1
    • Use a spudger to remove the rear camera.
  8. Pine64 PinePhone Front and Rear Camera Replacement: stap 8, afbeelding 1 van 1
    • Use a spudger to remove the front camera.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 370
