Ga door naar hoofdinhoud
Pine64 PinePhone Charging Port Replacement
Wat je nodig hebt
  1. Pine64 PinePhone Charging Port Replacement, Back Cover: stap 1, afbeelding 1 van 2 Pine64 PinePhone Charging Port Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Place the device face down on a non-scratch surface.
  2. Pine64 PinePhone Charging Port Replacement: stap 2, afbeelding 1 van 1
    • Using a fingernail pry open the back cover off with the bottom left indent.
  3. Pine64 PinePhone Charging Port Replacement, Charging Port: stap 3, afbeelding 1 van 3 Pine64 PinePhone Charging Port Replacement, Charging Port: stap 3, afbeelding 2 van 3 Pine64 PinePhone Charging Port Replacement, Charging Port: stap 3, afbeelding 3 van 3
    • Using a Phillips #000 screwdriver, remove each of the screws around the perimeter of the PinePhone.
    • Remove the battery.
  4. Pine64 PinePhone Charging Port Replacement: stap 4, afbeelding 1 van 1
    • Remove the midframe from the phone.
  5. Pine64 PinePhone Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Carefully lift up the vibrator, connected to the board by two wires.
  6. Pine64 PinePhone Charging Port Replacement: stap 6, afbeelding 1 van 1
    • Applying even pressure, lift up the board.
    • An adhesive is all that is keeping it to the frame of the phone, so there should be minimum resistance.
    • With a new adhesive strip, connect the replacement board to the frame. Make sure to secure the vibrator in the same place as the original.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 38
Altijd: 1,028
