Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Picstart Plus Development Programmer te repareren, gebruik onze reparatiehandleidingen.
  1. Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: stap 1, afbeelding 1 van 3 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: stap 1, afbeelding 2 van 3 Picstart Plus Development Programmer Teardown, Picstart Plus Development Programmer Teardown: stap 1, afbeelding 3 van 3
    • Remove 4 Phillips screws located on the back side of the holding plate.
    • After the screws are removed, remove the case of the development programmer.
    • Carefully take out the circuit board with component side facing up. Put the case aside.
  2. Picstart Plus Development Programmer Teardown: stap 2, afbeelding 1 van 2 Picstart Plus Development Programmer Teardown: stap 2, afbeelding 2 van 2
    • Disconnect the microcontroller module from the main board using a spudger or a similar tool.
    • Set the microcontroller module aside.
  3. Picstart Plus Development Programmer Teardown: stap 3, afbeelding 1 van 2 Picstart Plus Development Programmer Teardown: stap 3, afbeelding 2 van 2
    • Flip over the mainboard so that the component side is facing down and remove the small Pan head screws that holds the cover of the IC holder
    • Remove the cover of the IC holder.
  4. Picstart Plus Development Programmer Teardown: stap 4, afbeelding 1 van 2 Picstart Plus Development Programmer Teardown: stap 4, afbeelding 2 van 2
    • Remove the IC holder lever along with the small metal plate that covers the lever.
    • Set the lever and the lever cover aside.
  5. Picstart Plus Development Programmer Teardown: stap 5, afbeelding 1 van 1
    • Congratulations! You have completely dismantled the PICSTART Plus Development Programmer!
    • All the extracted components are shown in the picture.
Brad
656 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 2,732
