Inleiding
Use this guide to remove the rear brake caliper and rotor.
Wat je nodig hebt
Loosen the exhaust strap:
Use an 12mm wrench to loosen the exhaust band lock nut.
A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
Remove the 15mm nut securing the upper front corner of the swingarm.
Remove the 15mm nut securing the lower front corner of the swing arm.
Remove the 24mm rear hub nut. Having a friend hold the rear brake handle will help break it loose. You can also use an impact wrench to remove it if you cannot get enough torque with a hand ratchet.
There is a spacer behind the rear hub nut. It will slide off with little or no force.
Remove the five 10mm bolts securing the rear wheel.
Pull the wheel towards you, sliding it free of the rear axle.
Loosen the two 6mm Allen bolts securing the rear caliper.
Apply blue Locktite or a similar product to these bolts upon reassembly to prevent them from rattling loose.
Lift the caliper up and free of the brake rotor.
There is a spacer between the rear wheel and hub. It is not pressed on and should slide off easily.
The rear hub with rotor attached should now slide freely off of the rear axle.
Remove the five 10mm nuts, then the five 4mm Allen bolts they were locking into place to remove the rear brake rotor for replacement.
5 andere personen hebben deze handleiding voltooid.
