Ga door naar hoofdinhoud
Photive Hydra Battery Replacement
Wat je nodig hebt
  1. Photive Hydra Battery Replacement, Face Plate and Back Plate: stap 1, afbeelding 1 van 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra Battery Replacement: stap 2, afbeelding 1 van 2 Photive Hydra Battery Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra Battery Replacement: stap 4, afbeelding 1 van 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra Battery Replacement: stap 5, afbeelding 1 van 2 Photive Hydra Battery Replacement: stap 5, afbeelding 2 van 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra Battery Replacement, Battery (Prerequisite): stap 6, afbeelding 1 van 2 Photive Hydra Battery Replacement, Battery (Prerequisite): stap 6, afbeelding 2 van 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra Battery Replacement, Battery: stap 8, afbeelding 1 van 1
    • identify the two points that will need soldering.
  9. Photive Hydra Battery Replacement: stap 9, afbeelding 1 van 1
    • In this step you will perform the soldering to remove the positive(red) and negative(black) wires).
  10. Photive Hydra Battery Replacement: stap 10, afbeelding 1 van 1
    • Once the solder is removed your battery is now removed and can be replaced with the new battery.
Conclusie
Andrew Chase
352 Reputatie
3 handleidingen geschreven
USF Tampa, Team 11-3, Cheng Spring 2016 Lid van USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Leden
6 handleidingen geschreven
2 opmerkingen
Battery Replacement of the Photove Loudspeaker PH-BTW55
A very good description and easy to do, but: to replace a Battery to have to use a soldering iron is behind every tecnologie - must be „Made in China". Would I have know this on the first place I never would have bought this and I never will!
Rolf Luebbers - Antwoord
Why can’t you just cut the wires and then solder the cut wires together rather than de-soldering from the board?
Dan Bird - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,243
