Ga door naar hoofdinhoud
Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement
Wat je nodig hebt
  1. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement, Front Panel: stap 1, afbeelding 1 van 1
    • Before continuing, be sure your device is powered off.
    • Remove two 9mm Phillips #0 head screws from the bottom side of the speaker.
  2. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 2, afbeelding 1 van 1
    • Peel back the rubber feet from either side of the base.
  3. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 3, afbeelding 1 van 1
    • Remove four 9mm Phillips #0 head screws from the bottom of the speaker.
  4. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 4, afbeelding 1 van 1
    • Separate the base of the speaker from the upper housing.
  5. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 5, afbeelding 1 van 1
    • Remove four 9mm Phillips #0 head screws from the inside of the speaker case.
  6. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 6, afbeelding 1 van 3 Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 6, afbeelding 2 van 3 Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 6, afbeelding 3 van 3
    • Remove all cable connectors from the speaker motherboard.
  7. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement, Battery Pack: stap 7, afbeelding 1 van 1
    • Remove two 9mm Phillips head #0 screws from the battery holder.
  8. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 8, afbeelding 1 van 1
    • Remove four 9mm Phillips #0 head screws holding the battery pack in place.
  9. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 9, afbeelding 1 van 1
    • Disconnect the battery cable from the motherboard.
  10. Photive Artisan Portable Bluetooth Speaker Battery Pack Replacement: stap 10, afbeelding 1 van 1
    • Lift the battery pack from the board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
David Lennon
10.108 Reputatie
10 handleidingen geschreven
Cal Poly, Team 4-5, Maness Spring 2015 Lid van Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Leden
45 handleidingen geschreven
Één opmerking
TJmart.pk is one of the main Online Wholesale and Retail Shopping
Websites in Pakistan. our Company provides the latest and good quality of '''Bluetooth devices in Pakistan'''.
7 Days Money Back Guarantee. Authentic &
Reliable Products with High-Quality Standards Guaranteed. Fast
Deliveries All Over Pakistan.
No Fake Listing, No Hidden Charges Cash on Delivery
tjmart pakistan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 2,254
